WD My Passport HDD with APFS partition failing
DISK Issues
Apple Community Support inquiry
Hi all,
I own a 2019 16-inch MacBook Pro with macOS Monterey version 12.6.
I also own a 4TB Western Digital WD My Passport HDD with USB-C port.
When I acquired the HDD, I made a partition to enable TimeMachine backups: 1TB for backups and 3TB left for other use.
Recently, the HDD was mostly likely unplugged during one of the backups operated by TimeMachine.
Since then, the 1TB Backup disk does not mount (except when my Mac turns off because it’s out of battery and I restart it later with the HDD already plugged into it) and I cannot see the files in my 3TB disk (no matter what).
Neither changing ports, nor changing cable, nor switching computers (even Windows PC) makes anything work.
For the 3TB My Passport, the data seems to be there, running First Aid fails and unmounting the disk also fails.
For the 1TB Backup, I expect the data should still be there as well, but again, First Aid fails and mounting the disk also fails (the opposite of the 3TB one for mounting/unmounting).
When using the WD app, only the 3TB My Passport disk is recognized by it.
When I run WD Utilities’ “Diagnose”, all tests succeed except for a “SMART status failed.” error.
When using Terminal, the few commands I am using give the following:
~ %ls /Volumes/My\ Passport/whatever/
ls: fts_read: Input/output error
~ %diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *1.0 TB     disk0
   1:                        EFI <U+2068>EFI<U+2069>                     314.6 MB   disk0s1
   2:                 Apple_APFS <U+2068>Container disk1<U+2069>         1.0 TB     disk0s2
/dev/disk1 (synthesized):
   0:      APFS Container Scheme -                      +1.0 TB     disk1
                                 Physical Store disk0s2
   1:                APFS Volume <U+2068>Macintosh HD<U+2069>            15.4 GB    disk1s1
   2:              APFS Snapshot <U+2068>com.apple.os.update-...<U+2069> 15.4 GB    disk1s1s1
   3:                APFS Volume <U+2068>Macintosh HD - Data<U+2069>     906.0 GB   disk1s2
   4:                APFS Volume <U+2068>Preboot<U+2069>                 578.4 MB   disk1s3
   5:                APFS Volume <U+2068>Recovery<U+2069>                1.1 GB     disk1s4
   6:                APFS Volume <U+2068>VM<U+2069>                      1.1 GB     disk1s5
/dev/disk2 (external, physical):
   0:      GUID_partition_scheme                        *4.0 TB     disk2
   1:                  Apple_HFS <U+2068>My Passport<U+2069>             3.0 TB     disk2s1
   2:                 Apple_APFS <U+2068>Container disk3<U+2069>         1.0 TB     disk2s2
/dev/disk3 (synthesized):
   0:      APFS Container Scheme -                      +ERROR      disk3
                                 Physical Store disk2s2
   1:                APFS Volume <U+2068>Backup<U+2069>                  ERROR      disk3s2
~ %diskutil apfs list
APFS Containers (2 found)
+-- Container disk1 XYYYYYXX-XXYY-XYXY-XXXY-XXXYYXYXXXXY
|   APFS Container Reference:     disk1
|   Size (Capacity Ceiling):      1000240963584 B (1.0 TB)
|   Capacity In Use By Volumes:   924377505792 B (924.4 GB) (92.4% used)
|   Capacity Not Allocated:       75863457792 B (75.9 GB) (7.6% free)
|   +-< Physical Store disk0s2 XXXYXXXY-YYXX-XXYX-XYYX-XXYYXYXXXXYY
|   |   APFS Physical Store Disk:   disk0s2
|   |   Size:                       1000240963584 B (1.0 TB)
|   +-> Volume disk1s1 XXYXYXXY-YYXX-XXXX-XXXX-XXXYYXXYXXXX
|   |   APFS Volume Disk (Role):   disk1s1 (System)
|   |   Name:                      Macintosh HD (Case-insensitive)
|   |   Mount Point:               Not Mounted
|   |   Capacity Consumed:         15409774592 B (15.4 GB)
|   |   Sealed:                    Yes
|   |   FileVault:                 Yes (Unlocked)
|   |   Encrypted:                 No
|   |   Snapshot:                  XXXYXXYY-XXXY-XXXX-YXYX-XXYXYXXXYXXY
|   |   Snapshot Disk:             disk1s1s1
|   |   Snapshot Mount Point:      /
|   |   Snapshot Sealed:           Yes
|   +-> Volume disk1s2 XXYXYXXX-XYXY-XYXX-YXYX-XXXXYYYYYYXY
|   |   APFS Volume Disk (Role):   disk1s2 (Data)
|   |   Name:                      Macintosh HD - Data (Case-insensitive)
|   |   Mount Point:               /System/Volumes/Data
|   |   Capacity Consumed:         905984700416 B (906.0 GB)
|   |   Sealed:                    No
|   +-> Volume disk1s3 XXYYXYXY-XXXX-XXYY-YYYY-XXYXYXXYXXYX
|   |   APFS Volume Disk (Role):   disk1s3 (Preboot)
|   |   Name:                      Preboot (Case-insensitive)
|   |   Mount Point:               /System/Volumes/Preboot
|   |   Capacity Consumed:         578367488 B (578.4 MB)
|   |   Sealed:                    No
|   |   FileVault:                 No
|   +-> Volume disk1s4 XXYXXYXY-XXYX-XXXX-XXYX-XYXYXXYYYYXX
|   |   APFS Volume Disk (Role):   disk1s4 (Recovery)
|   |   Name:                      Recovery (Case-insensitive)
|   |   Capacity Consumed:         1117847552 B (1.1 GB)
|   |   Sealed:                    No
|   |   FileVault:                 No
|   +-> Volume disk1s5 XXXXXYXY-YXXX-XXYX-YYXY-YXYYYYXXYXXX
|       APFS Volume Disk (Role):   disk1s5 (VM)
|       Name:                      VM (Case-insensitive)
|       Mount Point:               /System/Volumes/VM
|       Capacity Consumed:         1073766400 B (1.1 GB)
|       Sealed:                    No
|       FileVault:                 No
+-- Container disk3 30526F51-86CD-4F98-BE59-59FE296EC0DC
    APFS Container Reference:     disk3
    Size (Capacity Ceiling):      ERROR -69620
    Capacity In Use By Volumes:   ERROR -69620
    Capacity Not Allocated:       ERROR -69620
    +-< Physical Store disk2s2 XXXXXYXX-XXYY-XYXX-YYXX-XXYYXXXYYXYY
    |   APFS Physical Store Disk:   disk2s2
    |   Size:                       1004615880704 B (1.0 TB)
    +-> Volume disk3s2 XYXYYYXX-YYYY-XYXY-YYXX-YXYYYXXXYYXY
        APFS Volume Disk (Role):   disk3s2 (Backup)
        Name:                      Backup (Case-sensitive)
        Capacity Consumed:         ERROR -69620
        Capacity Reserve:          ERROR -69620
        Capacity Quota:            ERROR -69620
        Sealed:                    No
        FileVault:                 No
~ %diskutil verifyVolume disk3s2
Started file system verification on disk3s2 (Backup)
Verifying file system
Volume is already unmounted
Performing fsck_apfs -n -x /dev/rdisk3s2
error: failed to read container superblock
File system check exit code is 8
Restoring the original state found as unmounted
Error: -69845: File system verify or repair failed
Underlying error: 8
~ %diskutil repairVolume disk3s2
Started file system repair on disk3s2 (Backup)
Checking file system and repairing if necessary and if possible
Performing fsck_apfs -y -x /dev/rdisk3s2
Underlying error: 8
~ %diskutil verifyDisk disk3
Unable to verify this whole disk: A GUID Partition Table (GPT) partitioning scheme is required (-69773)
~ %diskutil repairDisk disk3
Unable to repair this whole disk: A GUID Partition Table (GPT) partitioning scheme is required (-69773)
~ %diskutil verifyDisk disk2
Started partition map verification on disk2
Checking prerequisites
Problems were found with the partition map which might prevent booting
Error: -69808: Some information was unavailable during an internal lookup
I do not want to go further trying out commands without understanding the risks of data loss, etc…
I would just like to retrieve the data from the 3TB My Passport disk.
I do not so much care about the 1TB Backup.
Does anyone know what is happening and how to fix it without sending the drive to an expensive data recovery service company?
Would erasing or deleting the 1TB volume, container, disk be sufficient to fix the whole HDD? If so, I would like to make sure this does not affect the 3TB part of it, and that it would allow me to access it again.
If your APFS partition is not functioning properly, then repair the partition immediately to avoid data loss. You can repair the APFS partition using Disk Utility by following below steps:
  1. Open Disk Utility in your Mac system.
  2. Select the APFS partition and click “First Aid” tab and then click “Run”.
  3. If Disk Utility can’t repair the partition, it suggests the next action course. For example, “Disk Utility fails to repair the startup disk. Backup as much data as possible and erase this drive.”
In such case, recover data from failing partition with help of data recovery software.
Further, you can also check the below link for more details on how to repair APFS partition or how to recover data from corrupt APFS partition:
Hope it helps!
Given that your 1TB backup partition does not mount unless you restart your Mac with the drive already plugged in, it suggests a potential issue with the file system. The inability to access your 3TB partition, despite trying different ports and cables, adds to the frustration. When you run First Aid, the error message indicating that file system verify or repair failed. : (-69845) suggests that the disk may be experiencing corruption https://www.hаndyrecovery.com/fix-corrupted-hard-drive-on-a-mac/, which can happen if the drive was disconnected improperly during a write process. Since it seems the data is still present, you might want to consider using data recovery software designed for Mac, such as Disk Drill or EaseUS Data Recovery Wizard, to attempt to recover the files from the problematic partition.
Did you manage to fix the issue? I’ve had to fix corrupted hard drive mac a few times already, and each time I was able to resolve it by following the instructions in this guide: https://www.cleverfiles.cоm/howto/fix-corrupted-hard-drive-mac.html. It provides clear, step-by-step guidance on how to troubleshoot and fix a corrupted Mac hard drive. The methods are easy to follow, and it really helped me get my data back without causing any additional damage
Thank you for the help, guys. I had the issue two years ago and had to move forward with professional data recovery services (Ontrack), which worked. Others may want to look into your new solutions nonetheless. Feel free to share new solutions to fix this in the future.
Thanks for giving detailed answer. It works.
Factors like the USB cable or port issues, disk corruption, system bugs, and improper format of the drive could lead to the error you mentioned. Now reconnect your WD My Passport HDD to another port on your Mac or change a USB cable to see if the 3TB disk will show up. If not, try the following steps:
Restart your MacBook Pro and run the FSCK command from Single User Mode
Recover your important files from the corrupted external HDD, then reformat it to make it usable.
(This related tutorial should be useful, too - [Solved] Disk Utility First Aid Repairing Failed on External Hard Drives)
