WD Passport Studio Install and Encrypt on XP
Disk fails to locate drivers.  I ended up reformatting,
Now need software to encrypt the drive.  Can only locate encryption software for MAC…
What is/where is PC encryption software other than through XP?
If you have a recent Passport Studio like I do, those that are silver with a black top, you can’t encrypt them on Windows with WD software as it’s Mac-only.
The older Passport Studio with a label in the front DOES allow you to encrypt on Windows.
If you have a smartware drive, then you need smartware to set the password for the drive.  if you wiped out smartware, then you can go to support downloads and download smartware from there.
