Hello! Please help if possible!
This situation happened to me a couple of years ago with the same external hard drive. The disk was repaired to normal so I’m crossing my fingers that it can be again.
I have a Mac. My WD passport accidentally came un-plugged from it’s USB portal. Now it’s not recognized under Devices in the Finder window. When I run Disk Utility, it appears in the left column, in the list of devices as: 2.2 TB WD Media. However, when I select the First Aid tab, nothing appears - I can’t click the Repair Disk button or Verify Disk button.
What should I do? Can it be repaired? Thank you!
