I have a gray WD usb My Passport 1TB (Usb 3.0) It’s around 3 months old
I recently moved some files to it (important ones) then I was going to move it to the next computer
I plugged it in and it wont work. No white light blinking (totally no light) and it CANT be detected by my computers (tried multiple, usb 2 and usb 3 machines)
I could feel the part where the power cord is conntected, heating up (basically the lower part of the HD near the cord)
I changed cords and it also doesnt work
I conntected it to a mac and it says the power current is not enough
Removed the HD to find out that there’s no way I could get a connector for this. I have no idea what it’s called nor if there is ana available generic enclosure (slave) for this
What do i do? I feel like the data is still in there BUT i need a way to connect it withouth going through that WD port they had built in (oh what a pain!)
Did you connect the drive in desktop computer? If so, please do so and connect the drive into the back usb port. Keep in mind removing the drive from the enclosure voids the warranty.
Unfortunately, is not possible to connect a power adapter to the drive. I’ll suggest you to contact a data recovery company in order to retrieve your information.
