I have some problems with my WD My Passport HDD (USB3 2 To).
My motherboard is a Asus P8Z77 Pto / Thunderbolt.
If I connect the HDD in an USB2 port there is no problem.
If I connect the HDD to a port in the bottom of the motherboard (the Intel one it seems USB3 SS / UASP) the HDD is accepted but the speed is limited to 40-45 Mo / sec (not was I was expecting for this drive).
If I install it in the other port (the AS Media), nothing happens and after a moment I have an error message telling that the USB drive has a problem (is not recognised by windows) and to connect it again. After a few trties (even the front port ofm y case), the HDD can still not work.
I have tried with and without the drivers from usb (as Windows 8 accepts the USB3 natively). I have also applied the last firmware for the chipset (from Asus Web site).
Can you please tell me what I can do?
Thank you
Marc
Should I use the 7 days I have to return the product or is there something I am missing?
