Hi guys,
I have portable drive My Passport Essential with product number WDBACX7500ABL - 00. It’s with a capacity of 750 GB. It works fine, when it comes to noises and connecting to a PC. I don’t have problems here - recognized and connected everytime. But it can’t read files, that are already on it - it freezes and then it even freezes my computer. That happens on all computers I tried with (5-6 with win 7, and one with win XP SP2). Also it reads/writes/transfers files very slow, and it freezes sometimes, so i need to unplug it and make everything one more time till i have a succesfull attempt. It also doesn’t read files - i have pictures on it. I can see the thumbnails, but when i try to open one it just freezes. I have no more than 20 GB on it now, but the backups take about 350 GB of it!!! (I use at most 200 GB of it, but i delete the files once successfully transfered). Also when i try to delete the backups it freezes. The best way to transfer/delete files is one by one, when they are big or at 4-5GB portions maximum, if I don’t want it to freeze. Today i needed 1h to write 6 GB of files on it (total of no more than 10 files, all of them videos).
My question is : Is this normal, can i do something to try to fix it? When now, what options do I have to get i changed? What reason do I have to choose from the dropdown list? It’s in limited warranty or something like this till 08/20/2013.I bought it from Bulgaria (bot sure if I keep documents about it), but I’m currently based in Austria. Can i change it in Austria or i should wait till I go back to Bulgaria? The drive itself is not broken, it was kept in a WD case from the very first minute. It has only normal scratches on it from use mainy on the back of it. I see it’s still an actual product, even there are some new colours. Can I also get a different one if replaced, or I will get the very same colour?
With best regards,
Valentin
