I have an external WD my book essential 2Tb on win7.
It worked fine in the beginning, but now it’s having problems:
I can still write data on it, but when i try to access data on it or copy files back to my pc it disconnects after a while and then reconnects, interupting the transfer.
I downloaded the wd data lifeguard diagnostics. when I open the program the smart status is all green. When I run a quick test the following error pops up:
"quick test on drive 2 did not complete!
Status code = 07 (failed read test element), failure checkpoint =105
(unknown test)
smart self-test did not complete on drive 2!"
I can only press the OK button. (The hd doesn’t get disconnected though during the test, like with regular file transfers)
Anybody know what’s wrong?
Thanks
