My WD Hard disk was showing wrong storage like 31GB instead of 1TB. I tried with all options like format and Virus scan etc…
So Can i eligible for replacement or what?
Regards
Sandeep K
Regards
Sandeep K
You need to check the partition table. Reformatting doesn’t change the size of anything…
It is possible that the remaining space on your hard drive has become “Unallocated,” which is why you only see 31GB in “This PC.” “Unallocated” space does not appear in “This PC” (or “My Computer”); it is only visible using specialized tools like “Disk Management.”
This is a 9-year-old thread. If the OP meant 31MB rather than 31GB, it is quite possible that the original problem, and solution, is described here:
GigaByte BIOS bug results in loss of 1TB capacity:
