My 2 TERABYTE ESSENTIAL BOOK DRIVE IS NOT WORKING, PERIOD! ![]()
It shows that the power cords ar properly working and it lights up showing that it had power and is working. However, it DOES NOT appear in ‘My Computer’. This is a serious problem for me, as it contains my most valuable files. HELP PLEASE!![]()
Call WD Support line to walk you through the troubleshooting as i dont have all the information from you. Does it show up in the Disk management? What operating system are you using? What is the connection “USB2, USB3”?
Several reasons can lead to hard drive not showing up:
- hared drive is hidden
- partitions get lost
- drive is not enabled in BIOS
- unsupported or RAW file system
- virus attack
- faulty cable or port
You can check it again from these aspects. If it still not work, you can turn to a partition tool from google.
If the WD hard drive does not show up in “My Computer”, you can enter Disk Management (right click “My Computer”>“Manage”>“Storage”>“Disk Management”) to check if you can see the hard drive there. If it is visible right there, you can check if it shows unallocated space. If it is, you can create a new partition on it. But that will cause data loss. To ensure data security, you can run check whether there are some bad sectors on the drive via running Chkdsk.exe tool.
Step 1. Click Start button, input “cmd” in the Search field, right click the Command Prompt icon and select “Run as administrator”.
Step 2. In the Command Prompt window, input "chkdsk g:/"and press Eneter to check and fix found bad sectors on the flash drive. Replace “g” with your flash drive letter.
If that does not work, you might need a data recovery tool to get back your valuable files, then format it directly to solve external hard drive not show up in Windows.
First of all, you can press the Win + X keys on your keyboard and select Disk Management from the pop-up menu to check the status of your external hard drive.
If you are using a brand-new SSD, it likely needs to be initialized. Windows cannot detect a drive in File Explorer or store data on it until you initialize, partition, and format it.Follow these steps to set up your new drive:
Step 1: Initialize the drive. Find the uninitialized SSD in Disk Management, right-click it, and choose Initialize Disk.
Step 2: Choose a partition style. Select the correct disk in the pop-up box, pick either MBR or GPT, and click OK.
You can also use Disk Management to diagnose other issues, such as checking if the SSD is offline, missing a drive letter, or labeled as unallocated space.
For more troubleshooting steps, check out this guide - SSD Not Showing up in Windows 10/11? Follow These Simple Solutions
