WD External disk not showing up anymore even in Disk Utility
I’m contacting you because my WD external drive has not been working for a few days.
Indeed, it is not displayed on the finder and in the system report, there is no trace of the disk, even in the utility disk.
The only place I see the external drive mentioned is in the USB category.
It is named “Elements 25A2”.
And among the information that appears, I have the following:
Available current (mA): 900
Required current (mA) : 896
I checked in the activity monitor and I didn’t see any trace of the external drive on it or rather, I didn’t find anything at “fsck_hfs” and “fsck_exfat” so I don’t know what to do…
I even did a reset of the Mac’s USB ports but nothing changes.
I hope that the content is not lost and that the external drive can still be saved after a format…
I will be sharing with you the some of the feasible solutions that you can try to fix this issue:
  1. Manually show external hard drive in Disk Utility
  2. Reboot your Mac computer to recognize the external drive again
  3. Check the external hard drive in System Information
  4. Reset USB ports of your Mac
  5. Check for hardware and software updates
  6. Run a virus cleaner software
  7. Run Mac diagnostics to detect hardware issues
  8. Reset your Mac’s NVRAM or PRAM
  9. Reset the SMC on your Mac
  10. Ask for help from local technicians or data recovery services
Solution 1: Manually show external hard drive in Disk Utility
The external hard drive is not showing up in Disk Utility? You can check if you can see the ‘External’ option at the left sidebar. If so, you can try these steps to manually show it up.
  1. Open Disk Utility after you connect the external hard drive to your Mac.
  2. Move your mouse and put it on the “External” option. You will see the “Show” option. Then you can simply click on it.
  3. Check if you can see the external hard drive in Disk Utility again.
Solution 2: Reboot your Mac computer
Sometimes, it might be some data damage to your Mac system. Hopefully, this problem can be easily fixed by restarting. Rebooting will refresh your macOS’s tasks. You can choose the Apple menu > Restart. Or you can press and hold the power button and, when a dialog box appears, click the Restart or press R.
### Solution 3: Check the external hard drive in System Information
You connect an external hard drive to a Mac computer but it is not showing up in Disk Utility. And it won’t appear even after a re-startup. Where else you can find this external hard drive then? Probably, you should check it in the System information. System information is where you can find all information of external devices, the software, hardware, and network on your Mac.
  1. Go to Applications > Utilities > System Information.
  2. Click “USB” on the left panel, and check the external hard drive information.
    If you see the external hard drive there but it is not showing up in Disk Utility, the hard drive may be under repair by macOS. Go and check it in the Mac Task Manager - Activity Monitor.
  3. Click the Launchpad and find the Other folder. Then you will see Activity Monitor there.
  4. Open this tool and check if there is any process named “fsck_hfs” or something similar. (If your external hard drive is exFAT formatted, then it should be “fsck_exfat”.)
  5. Select that task and click the “Force a process to quit” button at the upper left to stop it.
Then the external hard drive should show up on the desktop of your Mac. And you can run First Aid in Disk Utility manually if you doubt any disk error.
Solution 4: Check for hardware and software updates
The outdated firmware and software results in various hardware issues. For instance, external hard drives won’t work on Mac because of an incompatible USB driver. You need to check for system updates by opening the App Store and clicking on the Update tab. If there are firmware and macOS software updates available, install them onto the Mac.
Solution 5:: Run a virus cleaner software
Another major problem is a virus infection, which will cause data corruption on the drive. You can try anti-virus software to wipe out and remove any virus, malware, or Trojan from your Mac computer and hard disk. Then check if the external hard drive is showing up in Disk Utility or not.
Solution 6: Run Mac diagnostics to detect hardware issues
Can’t see the external hard drive in Disk Utility still? You can try Apple Diagnostics. It is a set of diagnostic tools used by technicians to find faults. You can use it to isolate a possible hardware issue on your Mac. It also suggests solutions and helps you contact Apple Support for assistance.
  1. It is advised to disconnect all the external devices except the keyboard, mouse, and other useful devices.
  2. Reboot your Mac or you can power on your Mac if is powered off.
  3. Press and hold the D button on your keyboard. Hold the button until you would be asked to choose a language.
  4. After selecting your language, it will display a progress bar stating “checking your mac”.
  5. After completing the diagnostics, it will suggest the solutions for the errors diagnosed.
Solution 7: Reset your Mac’s NVRAM or PRAM
NVRAM is a small amount of memory on your Mac. It saves specific data regardless if the Mac is powered on or off. If you experience issues related to hardware, resetting NVRAM might help. PRAM stores similar information and the steps for resetting NVRAM and PRAM are the same.
  1. Shut down or reboot your Mac.
  2. Immediately press these four keys in a sequence i.e. command, Option, P, and R.
  3. Hold the keys for at least 20 seconds and after you hear the second chime, release the buttons.
  4. After releasing the keys, your Mac will restart and hopefully your drive will show up.
Solution 8: Reset the SMC on your Mac
If you have reset the NVRAM or PRAM, you’ve done it all. But what if your external hard drive is still behaving strangely? In certain circumstances, resetting SMC can be a solution. SMC, short for System Management Controller, is responsible for lower-level functions on Intel-based Mac computers. Resetting it can solve particular power and hardware-related troubles.
Reset SMC on modern Mac laptops with an internal non-removable battery:
This is how to reset the SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro’s with an internal non-removable battery:
  1. Shut down your MacBook Air/MacBook Pro.
  2. Connect the power adapter to the Mac.
  3. After your Mac shuts down, press Shift + Control + Option key combinations, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
  4. Release all keys and the power button at the same time.
  5. Press the power button again to turn on your Mac.
The boot time after resetting a machine’s SMC can be a bit longer than usual, that is normal.
Solution 9: Ask for help from local technicians
If unfortunately, your external hard drive has some serious hardware problems, no software can help you fix the external hard drive not showing up in Disk Utility. The only solution is to send it to a local data recovery service or replace it with a new one.
Whenever you connect an external drive to your mac, the storage drive may not show up on Desktop, Finder, or even on Disk Utility due to various reasons:
  1. USB connectivity problem
  2. macOS preference settings
  3. Partition map damage
  4. Device incompatibility
  5. Physical damage on a drive
However, to fix the issue, you can try the below methods:
  1. Check the USB connectivity
  2. Enable visibility of external hard drive
  3. Update macOS
  4. Repair external hard drive by using Disk Utility
  5. Repair external hard drive by using Terminal
  6. Erase the external hard drive
  7. If none of the above works, then the drive needs replacement
Further, you can also check the below link for steps to be followed in each method mentioned above:
Hope it helps!
I was having similar issues with my 8TB Passport not showing up anywhere, but I could still see it in disk utility. No matter what I did in Terminal or elsewhere I couldn’t get it to Mount or Eject. In my searching I found an app (I’m not trying to promote) called MacKeeper that does a free scan of your drives (internal and external). It noticed I had 15GB worth of Cache Data that it recommended I flush out. I did it and for some reason after that the HD showed up on my Desktop!
I assume their is a way to flush your cache without the app but I’m thinking that process might have helped reset something on my laptop or on the external drive, I’m not sure.
My WD external hard disk which was working well six months ago, slowly it took a long time to open and now it is not showing in my mac. The machine is running, small light is on but it is not showing. I even formatted the disk in a PC in which it is opening but it is not working in my mac. Please help.
It looks like you have a mechanical spin drive. Is it a 3.5" drive or a 2.5" drive? If it is 2.5" drive, and your system only show the PCB bridge information then back if the drive spinning up when you plug in. This is the same thing on the 3.5" drive. Check if drive spinning up.
If it is spinning, then check of your system able to mount it. If it is spinning up but no drive to mount then call WD technical support.
When an external hard drive isn’t showing up on your Mac, it can be due to various reasons, including hardware issues, software problems, or settings misconfigurations. Understanding the reason behind the problem is beneficial for you to choose the right solution. Check out this article to learn how to fix the “External hard drive not showing up on Mac” issue.
Is the USB cable is securely connected? If not, try a different port or cable and check if the drive is visible but not mounted in disk utility. Also, verify that external disks are enabled in finder preferences and change doorbell sound.
You can try the following steps to fix the WD external disk not appearing in the Mac Disk Utility.
Fix 1. Reboot Your Mac
Rebooting your Mac is one of the simplest methods to fix minor data damages and show the hard disk in Mac. This solution has had impressive success in fixing such initial issues on Mac. If you are dealing with the problem of the external drive not showing up on your Mac, follow these steps to reboot your Mac.
Fix 2. Edit Finder Preferences
When you connect an external hard drive, check if it shows in the Finder. If it doesn’t, you will need to edit the Finder preference to show external drives on the desktop.
Fix 3. Repair External Hard Drive with First Aid
If your Mac does not identify the external drive, there is a possibility of errors in the disk. You can utilize the First Aid tool to check and perform disk repair on the Mac without losing the data. It is an inbuilt Mac tool designed to identify disk issues and attempt the necessary fixes.
Fix 4. Mount External Hard Drive to Make It Showing on Mac
If your newly bought external hard drive is not mounted, it can not appear successfully on a Mac.
Fix 5. Format External Hard Drive with Disk Utility
If you formatted the external drive earlier on another device, MacOS might not recognize it. You must format the drive to make it Mac-friendly, and the system will identify it without any issues.
Fix 6. Reset NVRAM
The issue of the external drive not showing up should be fixed after the successful format. If not, the problem may exist in the nonvolatile random-access memory (NVRAM). Your Mac’s local settings are stored on NVRAM, which can create bugs, and as a result, the system does not recognize the external drive.
Fix 7. Use Terminal to Troubleshoot
Using the Terminal app is a final fix for all non-tech-savvy users because they tend to find it complicated. In addition, most users find it a bit tricky to use. However, it can fix the problem, and using the app is not that challenging. Using the given commands, you can solve the external hard drive not showing up on the Mac issue.
Fix 8. Contact Data Recovery Services to Fix the External Hard Drive
If you think the above methods are too complex or cannot fix the not-showing problem perfectly(Sometimes the external hard drive does not show up in Mac Disk Utility), try to contact EaseUS data recovery services
There are a couple of reasons why can’t i see files on my external hard drive mac. Sometimes, it’s due to file system compatibility issues, hidden files, or even drive corruption. If you’re experiencing this problem, I came across a helpful resource that goes over the most common causes and solutions. You can find more information in https://www.hаndyrecovery.com/files-disappeared-from-external-hard-drive-mac/, which outlines possible reasons why files might disappear from an external hard drive on a Mac and how to recover them.
Everyone has offered some great solutions here—thanks for sharing! When I started researching why can’t i see files on my external hard drive mac, I came across this article: https://www.cleverfiles.cоm/howto/files-disappeared-from-external-hard-drive.html. It really cleared things up for me and provided some practical steps to resolve the issue. If anyone else is dealing with missing files on their external drive, this guide might be a good place to start. Let me know if it helps or if you have other recommendations
In your case, if the [External disks] option in the Finder - General tab is checked, your WD External disk may be inaccessible due to physical issues, such as a faulty USB port or cable. If these simple factors don’t have any effect, then that’s the worst scenario - your WD disk is corrupt.
