WD Elements PC problem
I’m new in this forum, first time with an issue with a drive, and it’s a weird one.
Iv’e been searching some posts to see if someone had the same problem, but dind’t find anything.
When I plug in my drive to any PC, it shows as WD elements in the devices, but I can’t access it, nothing can be done with the drive on any PC. But if I plug it in my TV, there is no problem, I can see every file in there and use them with no problem.
Any idea on haw I can get the drive to work again on a PC?
Welcome to the Community.
Have you tried Disk Management? It is possible for the drive to need a drive letter in order to mount.
http://wdc.custhelp.com/app/answers/detail/a_id/137/
Thank you.
I have tryed disk management, the drive shows, it has a letter, but if freezes and I can’t do anything, I have to force shut down disk management.
I have tryed updating firmware, didn’t work. Tryed WD data lifeguard, and it gets an error and cant do the test. Something is really wrong here.
Do you have a backup of the drive’s data? You may need to format it.
I tryed different windows, none could access the drive. After trying many different HDD recovery software that didn’t help at all, I decided to try the simple old school method. Just ran the CMD, did the CHKDSK /F, and after it was done, my drive was visible again, and working normally.
Problem solved.
