i got recently a new WD Elements, the issue is that after change the name and put some documents there, it stops working, i can see the device on the divece manager but not the disk on the disk manager.
I found that maybe the disk manager wasnt changing the name, but if i even try to change i cant not found it.
i’ve tryed to make the test with the software that WD recommend, Data Lifeguard but even that software cant recognice the disk.
Any suggestion?
