I saw some discussion on this forum about the above subject but not really a solution to fix the problem…
I have a WD Elements, 1 Tb that I bought in an IT shop in Papua New Guinea about 10 days ago. It worked good on the first week then suddenly is not detected as a folder when I plugged into my laptop. Although, I can see that as a hardware, as it goes on/off when I plug/pull the device.
My questions are:
- How to fix the problem to make the device opened again as a folder. Thus, I can retrieve my files.
- If 1 is not possible, is there a way to retrieve my files?
Best Regards,
Bobby
