'I used my WD Elements 1TB external hard drive to perform system recovery for my Dell PC running Windows 10, After that my 1TB external hard drive storage capacity changed to 32GB. Please advise how I can recover the original size of the external hard disk 1TB?
Hi DavyMj ,
May be you need to format the drive in NTFS file format in order to utilize the full capacity. Make sure , formatting is a data destructive process. You can refer to the link below:
Hi Peter G
Thank you for the prompt response to my query.
The solution you advised worked fine and I have managed to recover the full 1TB.
Kind regards
Hi DavyMj ,
We’re glad its working fine now. Appreciate your feedback.
Thanks!
