Hiya all. I need to access my Elements drive and save work to it, but it says the drive is “write-protected”. I don’t know how to revoke the read-only settings on it, but I was wondering if someone else might know? Thank you for any responses.
When your external drive or any storage drive shows up as “Read Only” on your mac, then you might be encountering a very common problem with the hard drive. In such a situation, the user can open and view the files on a drive but cannot copy or move files to the storage drive. The possible reasons for this issue could be:
- External drive is NTFS formatted
- Disk permission changed as “Read Only”
- External drive is corrupted
However, the issue can be fixed using below DIY methods:
- Reformat the external drive
- Change/Ignore permissions on an external drive
- Repair external drive with disk utility’s first aid
Hope this will help you fix the issue!
