WD Element - PCB Firmware needed for 3TB drive
I’ve a WD element with 1.5TB drive in it. I replaced the drive with 3TB but Windows 10 showing it as 746GB drive. So I gathered that he USB controller inside the enclosure need firmware update. Does anyone know where I can find the firmware?
Thanks
why don’t you just buy a cheap USB3.0 3rd Party Enclosure for your 3TB Hard drive ?
that will 100% Guaranteed to work.
i’m pretty sure you won’t find the firmware you’re after (if it even exists) … and if you go messing around with flashing firmware to do something that is out of warranty (shucking) and WD doesen’t support (or condone) there’s a good possibly you will brick your 3TB hard drive.
All for what ? … something that’s easily solved by buying a $15 or $20 third party enclosure.
