Hello ,
I have a WD Element Desktop 4 TB it works perfect but I can get a connection with WD Drive Utillities when I open it I get mount a supporting WD drive.
Any suggestion is welcome.
Regards,
JD
Rotterdam
The Netherlands
Hello ,
Regards,
JD
Rotterdam
The Netherlands
Hi @Diepe745,
This is to inform you that WD Drive Utility does not support the WD Elements Desktop drive.
Here is the WD Elements Desktop drive downloads link: https://support-en.wd.com/app/products/product-detail/p/264#WD_downloads
However, In order to understand the health of the drive, we would request you to install WD Dashboard Application.
Thanks for the reply , why do they not chance that I assumed that every download works .
Turned in WD Elements by the retailer and bought a My Book 4 TB.
There is no software for WD Elements on the page link you provided. If WD Drive Utilities do not support WD Elements, then what software does?
