Hi all ive got a MSI B450 Tomahawk mobo and a couple of years ago i installed a WD Blue SN550 1TB M2 drive and up until a couple of days ago ive had no problems.
Its showing as installed in the Bios but not in disk management or the WD Dashboard ive tried updating the bios and all the other drivers still with no success.I even did a CMOS reset and still no difference
The only thing ive done in the last week is i downloaded and used Winzip Driver updater but after i found out its basically a scam i uninstalled it.
Has anyone got any suggestions what i can do or do you think i just need to buy a new drive?
Hi @W1ldheart,
Please refer to the link to check the article on Windows or macOS Cannot Find My Drive:
Please refer to the link below for downloading the SSD dashboard and please perform the SMART diagnostic test and share the test results:
Hiya i actually sorted it out by going into device manager and uninstalling the AMD Raid Driver in Storage Controllers
