I just got a new Lenovo Legion 5 and wanted to get some additional storage so I bought the “WD Blue 3D NAND SATA SSD M.2 2280” however after installing it hasn’t appeared in my devices and drives or my disk management what do I do?!
Hi @Topxav,
Please refer below link Windows or macOS Cannot Find My Drive:
Please check & try to fix the below issue:
- Initialize your SSD in case if it is not initialized.
- Assign a drive letter to your SSD.
- Check if the SSD file system is supported by Windows or not.
- Check if the SSD disk driver installed properly or not.
hopefully, your drive will be recognized.
