WD Backup 1.0.5953
I’ve installed this version of WD Backup on my Windows 7 machine and when I go to select my files to back up, I see:
Notice there’s no carat next to the ‘my computer’ selection, despite the fact that I have 4 hard drives I need to back up.
I’ve tried re-installing the software, doing updates, etc. No luck. I should mention that I have installed the 1.5.5953 update that was released recently.
Any thoughts??
Indeed, you should be able to expand your system and select your volumes:
What happens if you use WD SmartWare as opposed to WD Backup?
