Hello community, I hope you can help me.
I broke open a new box with a “My Passport Ultra” 3TB drive and installed the WD software that was on it to backup my Windows 7 C: drive to it. I used the instructions on p. 11-20 (chapter name: “Backing Up Files” of the My Passport Ultra Portable Hard Drive User Manual PDF, dated April 2015). The manual seems well-written and the instructions clear, and everything went uneventfully as documented until the point of the diagram on p. 17 (shown below from the user’s manual) that shows what one should see:
However, what I actually see on the screen is the following:
I see a label “My Computer” and that’s it! The little arrow for expanding the contents of My Computer is missing, and no drives are listed under it (I only have the one internal drive, C:, to backup).
Can anyone tell me how to make drive C: visible to the WD Backup software? The machine is not connected to the Internet–it’s old, and I wanted to make sure it was backed up before updating its security software.
Thanks.
- Bob
