OK. Sorry if this is a bit of a noob question, but here goes.
I’ve ordered a WD Elements 1TB external HDD (WDBUZG0010BBK). I know it comes with a USB3 cable which’ll be great for attaching to my desktop which does USB3. Great.
However, I have a laptop and I’m getting a WD TV Play Media Player (WDBHZM0000NBK) both of which only use USB 2.0. I need to know exactly what kind of USB 2.0 cable I’ll need to hook up this drive please.
One end is obviously a USB 2.0 A connector. But precisely what type of connection is required at the drive end? A regular B connector? Mini B connector? Or is it a Micro B connector.
That way I can order a couple of the right type of cables before the drive arrives. I surprised this info isn’t specified in the documentation for this product.
Thanks in advance.
meson1
[EDIT] OK. I’ve completely misunderstood. I have suddenly realised that I don’t need a USB 2.0 cable at all. I can just use the USB 3.0 cable supplied with the drive in a USB 2.0 socket and it’ll work just fine in USB 2.0 mode. I’m now going to go kick myself. ![]()
What I could do with is just a longer USB 3.0 cable, which should just be USB 3.0 A to Micro B, yes?
