Hi. My firmware version is V01.01.22A, my previous firmware - I’m not sure (I’ve bought fuze 2 days ago, it was in a new, colorful box, not the navy one). Probably it was either 01.01.07 or 01.01.11 or 01.01.17, but I’m not sure.
I’ve updated the firmware today to 22A and uploaded a few mp3, ogg and flac files (at the same time). I’ve found that fuze changes tracks by itself:
There are two different instances of skipping:
The song is playing, backlight is off, I’m trying to turn the volume up or down. In this case fuze treats wheel rotation as click either to the right or to the left, changing the track. It wasn’t like that when I was playing with fuze before update.
The song in OGG or FLAC format is either playing OR PAUSED (why does it happen when it’s paused?) and the backlight turns itself off (afther that 10 seconds), fuze skips to the next track (and lits the backlight). So the backlight is off for just a quarter of second, then it immedely turns on and I see the next track playing at 0:00 - it’s always the next one, never the previous one.
This is the summary of a sample FLAC file that skips:
File Name : 09 I Like the Boom.flac
File Path : F:\Muzyka\Techmaster P.E.B\09 I Like the Boom.flac
Subsong Index : 0
File Size : 25.8MB (27 111 979 bytes)
Last Modified : 2008-12-19 12:51:05
Duration : 4:03.879 (10755072 samples)
Sample Rate : 44100 Hz
Channels : 2
Bits Per Sample : 16
Bitrate : 889 kbps
Codec : FLAC
Encoding : lossless
Tool : reference libFLAC 1.2.1 20070917
Embedded Cuesheet : no
And here is the summary of a sample OGG file that skips:
File Name : 3 Energy 52 - Cafe Del Mar (Dabruck & Klein remix).ogg
File Path : F:\Muzyka\Transcode_mp4_to_ogg\3 Energy 52 - Cafe Del Mar (Dabruck & Klein remix).ogg
Subsong Index : 0
File Size : 5.19MB (5 451 891 bytes)
Last Modified : 2008-12-19 13:56:47
Duration : 3:31.835 (9341924 samples)
Channels : 2
Bitrate : 206 kbps
Codec : Vorbis
Encoding : lossy
Tool : Xiph.Org libVorbis I 20070622
<BITRATE_NOMINAL> : 192
There is one OGG, however, that works just fine
File Name : 06 (Slip & Slide) Suicide.ogg
File Path : F:\Muzyka\Kosheen\Kosheen - Resist\06 (Slip & Slide) Suicide.ogg
Subsong Index : 0
File Size : 3.78MB (3 967 788 bytes)
Last Modified : 2008-12-19 13:37:03
Duration : 3:35.133 (9487380 samples)
Channels : 2
Bitrate : 148 kbps
Codec : Vorbis
Encoding : lossy
<BITRATE_NOMINAL> : 160
Could you please give me a way to get to some other firmware that doesn’t have those bugs? I’d appreciate firmware that supports OGG (FLAC is not necessary).
Please let me know if you need to know more details
Thanks,
Amadeusz
Message Edited by meush on 12-20-2008 10:24 PM
