Using My Passport as a storage device
I know this is probably a silly question, but is it possible to use My Passort as a removable storage device. I have several large files that I need at work but also need to be able to access and alter them at home.
Is there any way this can be done?
Of Course!!!
Even When The Passport Comes with the Wd Smartware , However the passport Still Works As a Normal External Storage Device
Under My Computer / Computer you Will see the Passport > Only thing That you need to Do is Drag & Drop , Copy & Paste , Send to files to it and there You Go!..
Heres a Link In Case you Wish extended Info on how To transfer files to your external Drive…
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1198&p_created=1080170577&p_sid=QqQSUjck&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0xMTk4&p_li=&p_topview=1
Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the ‘Accept as Solution’ button for the post that solved your issue. This may help someone else.
If you need any other Info let me know…
