Used space
I just purchased a 1 tb My Passport and right out of the box it shows 929 GB free space and 1.51 GB used space. Is this normal? What could be taking up that much used space? Thanks in advance.
It may be software. If you don’t see any files check for hidden files. Also look in Disk Management and Device Manager and see if there are any virtual drives.
Joe
Thanks for the reply.
The only files are the ones that came on it. They don’t add up to 1.51 GB. Also checked disk management and didn’t see any virtual drives. Any other ideas?
