I saw someone had a USB flash drive that they put in their phone and I just have to get one of those… But now trying to buy online and I’m not sure what to look for… I have a hauwei p20 which has a type c charger port, so if I get a USB flash for that…i won’t be able to plug it into the desktop or my laptop as those have the normal USB ports…
I saw online they have a dual one… Is that what I need to get to be able to plug it into my phone and desktop to transfer files between to the two or is there another spec I should be looking for?
I understand you want to buy the OTG dual drives for your hauwei p20 Type C mobile.
Please refer below links to check detail features of supported drives:
Please note that the best way to ensure you are purchasing an authentic SanDisk product is to buy from an authorized SanDisk reseller. You may view our reseller list to locate an authorized SanDisk reseller in your area:
