Updater not working, second
This message was posted 15 days ago, and as not received any answer …
I have a Sansa Express 2 GB with 01.00.15F2 firmware
I have installed the Sansa Updater 1.041
When i plug my Sansa Express, a windows say : you are in Europe (true)
and a new firmware 1.01.01 is available.
When i click on “Update now”, apparently, the firmware is downloaded, bat
after waiting a while at 100%, the message : "Failed to download the required
firmware files". “Firmware update cannot continue at this time”. "Please try
again later" …
I am trying from 10 days, morning and late … ever the same answer …
Thanks for a quick solution.
does it happen anywhere you take the device to try it on? multiple computers?
Message Edited by Enigma on 08-07-2007 10:16 AM
again later" …
I would contact sandisk tech support. they can email you the firmware.
First, excuse me for my poor english.
I made test with two different Sensa Express, on three different computer …
In English, I have choice : Europe or Israel   ??? same stop after few minutes …
I have contacted the Swiss distributor … no answer …
I suspect Sandisk not support the product …
@pragmatec wrote:
If you’re downloading your firmware updater here then you shouldn’t have any issues.  If you say that you have a 01.00.15F2 firmware then the updater should be compatible.  Check to see which options you are choosing.  If you find yourself choosing Europe, try choosing Americas and Vica Versa.
I use the version  1.041 of Sansa Updater and the proposal
is : Europa or Israel ( why this limitation ??)
Both choice not working
