Unable to View my files and folders copied to WD Passport
Dear all,
Six months ago, I backed up my files and folders from Dell Laptop (hard disk) to WD Passport. I was able to transfer files and folders successfully and view them later on WD.
Later, I changed my hard disk to an SSD type on the same Dell laptop. After changing the hard disk to an SSD, I tried to view my backup again on WD Passport, but the files and folders were not found. However, I can see the backed-up files and folders on my colleagues laptops and also on desktop computers.
I tried to open WD passport files on my Macbook, but I am unable to see the files on my Macbook either.
I need your kind advice and help to sort out my issue.
Hi @Dr.Santhana,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
Hi, Thanks for the support.
Do you mean about the WD CD? I lost the CD associated with WD. kindly advice further.
If your drive is showing data on your colleagues then the best option would be to take backup of the data on some other drive and then consult the support for the drive you are facing problem with. You can even try a few solutions to make it work, firstly make sure your WD Passport is formatted as NTFS or exFAT (compatible with Windows). Update USB drivers in Device Manager, run a disk check using Command Prompt (type chkdsk X: /f), and assign a drive letter in Disk Management if needed. Try different USB ports and cables for connectivity. These steps should help you view your backed-up files on your Dell laptop without issues.
First, check the format of your external hard drive in Windows File Explorer:
  1. Connect your external hard drive to a working computer, such as a colleague’s laptop.
  2. Locate your WD Passport external drive under This PC or My Computer.
  3. Right-click on the external drive, select Properties, and check the File system under the General tab. It will display NTFS, exFAT, or FAT32.
Then, use the built-in Error Checking Tool in Windows to scan and repair drives. This tool works for NTFS, exFAT, and FAT32 drives, similar to the command-line chkdsk.
  1. Open File Explorer and right-click on the problematic WD Passport external drive.
  2. Select Properties, go to the Tools tab, and click Check to scan the drive for file system errors.
If you want to access the external hard drive on a Mac:
  1. Run First Aid in Disk Utility to check and fix minor issues on the external hard drive.
  2. Use Terminal to detect, recognize, mount, and display your My Passport drive.
  3. If necessary, back up your data, then reformat the drive to exFAT for compatibility with both Windows and Mac, or APFS if you plan to use it only on Mac.
  4. Reset the NVRAM to help your external drive appear on your Mac.
  5. Boot your Mac in Safe Mode and remove any third-party software that might prevent the external drive from mounting.
If you’re unsure how, see: Fix External Hard Drives Not Showing Up on Mac.
