Ultra Slow! Transfer rate with Ultra Dual Drive Go USB 1TB on MacOS/ExFat
Hi there,
Takes about 1h to transfer 818MB from my MacBook (RAM-8GB) to the Ultra Dual Drive 1TB, who becomes very very hot.
Writing/reading speed is correct on my Dell PC notebook & Lenovo Android Tablet. The drives doesn’t get even warm. The problem lies with MacOS.
I bought the USB drive 4 days ago and transferring files from my MacBook takes ages! What’s wrong? the driver? I restarted the MacBook (Sonoma 14.4.1) nothing changes.
Thanks a lot!
@grincement
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
Hi, thank you. Yes I checked the knowledge base and didn’t found an explanation for the latency. It seems to be related specifically to this Sandisk Drive. I don’t have this problem with other drives working with exfat system file.
It could be a MacOS compatibility issue or power management limiting speeds.
Try formatting the drive to exFAT using Disk Utility and see if that improves transfer times.
First, try changing the USB cable to see if the data transfer speed improves.
Next, disable the Spotlight Search indexing function on the external drive.
Additionally, you can use macOS’s built-in tool, Disk Utility (First Aid function), to check for errors on the external drive and repair them.
Finally, consider reformatting the external drive to the macOS-native APFS format to potentially improve transfer speeds. (Also read: [Fixed!]Slow External SSD and HDD on macOS Ventura)
