Should the WD My Passport Ultra remain plugged into the PC or unplugged after downloading?
That’s optional, if you are running a continuous backup, will be better if the unit is connected all the time. Now, if you are just using the unit as a storage device to play or use files from the drive, just plug it in when you are using using it.
Thank you for the response.
