The parameter is incorrect error
Can someone help me? I plugged my Passport 1 TB external drive into my USB, it shows up in the File Explorer as Local Disk (D:), it shows up in the Device Manager as WD SES Device USB Device. But when I try to access my files that are on there, I get this message:
D:\ is not accessible
The parameter is incorrect.
“The Parameter is incorrect” is one of the common issue related to external drives which may leads to 2 major issues:
i) Cannot Copy Files
ii) Drive becomes inaccessible
The parameter is incorrect issue can be occur due to various reasons like Virus infection, Unsafe removal of hard drive, Power failure, Bad sectors and Corrupt file system. Though the issue can be resolved; below are the few possible solutions to fix the issue:
  1. Run CHKDSK
  2. Run SFC Scan
  3. Use Antivirus Program
  4. Format the external drive
Further, you can check the below link to know the detailed process to fix the issue:
Hope that will help!
Plug the external drive into a different USB port. If possible, try using a different USB cable or try the drive on another computer to rule out a cable or port issue. It happens all the time that drive is not accessible the parameter is incorrect and here https://www.hаndyrecovery.com/drive-is-not-accessible-the-parameter-is-incorrect/ you will find how to fix this common issue.
What did you end up doing to resolve it? I recently encountered the drive is not accessible the parameter is incorrect issue as well, and it was such a headache at first. Thankfully, I found a really helpful guide here: https://blоg.7datarecovery.com/the-parameter-is-incorrect/. It walked me through the troubleshooting process step by step, and I was finally able to fix the problem. If you’re still stuck or know someone dealing with the same issue, I’d definitely recommend checking it out. Let me know if it works or if you have any other tips to share
The error “The parameter is incorrect” can occur due to various reasons, such as file system corruption, connection issues, or incorrect partition settings. You can try some very basic troubleshooting steps at home, but if everything fails, get someone better than you are with computers to help.
thanks for the information.
Your computer can identify correct file systems, such as FAT, exFAT, FAT32, and NTFS. But when a drive’s file system is missing, unrecognized, or corrupted, Windows will show it as ‘RAW’. In this case, you will see a warning message like “The drive is not accessible. The parameter is incorrect.” or “Location is not available. E:\ is not accessible. The volume does not contain a recognized file system.”
This state often stems from improper ejection, malware, bad sectors, or issues with partitioning. When the file system is absent or damaged, the Windows operating system cannot read or write to the drive until you successfully repair or reformat it.
Even though you cannot access the drive, the data remains intact. It’s recommended to use data recovery software to recover files before attempting to reformat. (Be noted: reformatting the drive will restore its file system, but it will erase all data ).
Read further in this blog to learn more - How to Fix RAW External Hard Drive without Formatting & Recover Files?
