facing parameter error …or location not accessible error…please help me in recovering data…on D Elements
“The Parameter is incorrect” is one of the common issue related to external drives which may leads to 2 major issues:
i) Cannot Copy Files
ii) Drive becomes inaccessible
The parameter is incorrect issue can be occur due to various reasons like Virus infection, Unsafe removal of hard drive, Power failure, Bad sectors and Corrupt file system. Though the issue can be resolved; below are the few possible solutions to fix the issue:
- Run CHKDSK
- Run SFC Scan
- Use Antivirus Program
- Format the external drive
Further, you can check the below link to know the detailed process to fix the issue:
Hope that will help!
The file system of your WD Elements hard drive is unrecognized, corrupted, or damaged, resulting in error messages indicating the drive is inaccessible. The possible causes include improper ejection, bad sectors, sudden power failures, and malware attacks that damage the partition table or file system structure.
If you want to get your data back, you can try these steps:
- Run specialized software to fix the RAW drive.
- Update the driver to fix the RAW drive without needing to reformat it.
- Convert the file system to NTFS using DiskPart.
[ Find more solutions in this how-to blog - How to Fix RAW External Hard Drive without Formatting & Recover Files? ]
