Strange noise in the 4TB drive ... help!
Last night the My Passport 4TB external portable drive connected to my Mac Mini failed to show up. I plugged it into my laptop, a MacBook Pro and heard strange screeching noise coming from it.
Spent all morning going through YouTube but couldn’t find a similar case. So I finally opened up the drive and found that the top platter was spotless. The heads seemed in alignment and in their place.
Can someone please guide?
Thank you.
Here’s what it sounds like.
Hi TheOtherShahab,
You can follow the link given below to know more whether the drive’s noise is normal or not.
You can also contact WD Technical Support team for the same from the links given below.
The link below will allow you to call support.
