Stopping the VCD from showing
hello everyone,
So I im not sure if i have the Passport essential or the essential SE. whats the diference. its only 500Gigs.
Anyways I have been using this a few times and it getting annoying seeing the WD virtual CD keep popping up everytime i plug my HDD in.
I looked up hot to disable the VCD and the website says to update the firmware and the run the VCD manager.
I have been following all this correctly and STILL i cant disable the VCD on the HDD.
I run the firmware update and it says its update, all i have to do is unplug it, restart my MacBook Pro and then plug it back it back in.
It still says i have to update the firmware. I did this 10 times… Whats going on?
is their an alternative way to disable or get rid of the VCD so i dont have to see it again?
If anyone help i would really appreciate it
Thanks in advance!!!
I don’t know what you call it on a Mac. In Windows I went into the device manager and disable the VCD.
Joe
i tried doing that on my PC but it still didnt work
