When I first installed SSD Dashboard it detected my drive fine.
Since then It now does not detect the drive.
I have it connected via a Sata to USB adapter.
I have uninstalled it and re-installed it 3 times with no result.
Many hits on web search tells me this problem is very widespread.
Please fix your SSD Dashboard so I can maintain my drive.
Thanks.
edit: just found this in current version release notes.
version 2.3.3.0 (10/12/2018)
“Added workaround for USB SATA dongle hardware connectivity issues.”
Presumably it should find ssd conncted with usb/sata but it does not.
Problem was with the usb/sata connector. Used another brand and it is now fine.
