[UPDATE]
This appears to be a bug with Dashboard 2.0.1.0. Dashboard 1.1.4.5 discovers the drive fine. My OS is Windows 10 x64.
Original
I picked up a WD Blue 250 GB SSD. It is installed and running my OS (Windows 10). Obviously the bios sees it. Windows sees it. Disk management sees it. However, dashboard does not see it. The drive is set to AHCI and solid state drive in the bios.
Is there some other trick to get dashboard to see the drive?
The only anti-virus running is Windows Defender. Would this affect Dashboard? All defender settings are set to warn and not block, so I would expect a prompt if that was blocking it.
I’ve also got a 500gb WD Blue m.2 SSD that the Dashboard isn’t detecting.
I’m running my Controller in RAID mode, as I’m running a RAID 10 on the system (but the m.2 is a stand-alone boot/OS device).
