SMART Status on macOS
Hello
I’ve noticed that using Windows WD Dashboard I can check the SMART status of the drive with info about the previous usage of the device. Why isn’t smart checking supported on macOS? Do I have to install anything more? I have already installed the DriveDX SAT SMART driver so I’m usually able to see the status of any other usb SSD/HDD.
Hi @gio91ber
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
This support page should be helpful for you:
Alternatively, you may refer to the methods mentioned here to use Terminal, SMART Status, and third-party apps to check the health of your internal or external hard drives:
How to Check Hard Disk Health on Mac [Best 4 Ways]
