If you can access the files through WD SmartWare then your device should be ok.
Please try the following:
Open Spotlight and search for Disk Utility, once there see if the drive shows up, if so try using the Reveal option, if that doesn’t work, try repairing it if that’s the case, use First Aid if you can see the drive.
