sdcard 64go high endurance not work on windows 11
SDcard 64go high endurance not work on windows 11
impossible to format., the actual format seem be RAW.
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this these.
(Contact Support | SanDisk)
Try these steps:
Disk Management: Press Win + X, open Disk Management, and try formatting to exFAT or NTFS.
Diskpart (Command Prompt): Use diskpart to clean and format the card.
SD Card Formatter: Download from the SD Association website and format the card.
Check Write Protection: Ensure the lock switch is OFF.
If the SD card still doesn’t work, it may be faulty and should be replaced under warranty.
Windows requires a proper file system (such as FAT32, NTFS, or exFAT) to format an SD card. When an SD card becomes RAW, its file system is either corrupted or missing, making it unrecognizable to your computer. You can use Windows’ built-in error-checking tool to attempt to fix the RAW SD card or use Diskpart to format it. Afterward, the SD card should be usable again.
Some more tips: How to Perform RAW SD Card Recovery: A Definite Guide
SD cards <= 32GB use FAT32, bigger ones use exFAT
SD cards are not designed for primary storage. Every image saved incrementally affects the flash memory so its advisable to replace the camera storage maybe every 2 years depending on use. Heavily used camera may be best off with annual replacements.
CF cards are designed around ATA and have been used for older machines without major problems. Adapters for EIDE to CF exist. The problem is that write endurance is limited. CD cards are SLD or MLC based which has better endurance than TLC or QLC.
