I’d like to be able to create Go Lists on the Fuze and then save these lists as .m3u playlists. Is this possible, either within the Fuze or via USB? Thx
Don’t believe so. While both the Go List and playlists are similar in function, they are totally different in the way they are contructed, formatted and saved on the device.
Thanks.
If there is one feature my fuze it lacking - it’s this
Yes, it would be cool to save the GoList as a permanent playlist, effectively giving you multiple GoLists. I’d guess that we could name them numerically, since naming them from the device itself would require a new interface for the alphabetical tasks.
Bob ![]()
what about saving the go lists separately on the device? I would like to do that so I can make multiple “go-lists”
Sorry, only 1 per customer. ![]()
I’ve asked about this before. I end up having to remember what was on there and create it again on a pc.
Instead of remembering, I go through the go list on my Fuze, having the Fuze in my hand and reading it, and went into Media Monkey to create my go list as a play list (because firmware updates have deleted it in the past). I haven’t tried moving to a playlist on my Fuze yet. I like it as a golist and add to it as I want to.
