The player doesn’t remeber where i stoped. It always begins from the beging after turned off power and on again.
Is it possible to make the player remeber this and start playing where i stoped?
/johtho
/johtho
Try putting it on pause first. It should work without pause on but
give it a try.
Many Tanks for your answer.
I have already tried that, but it didn’t help.
some more tips?
what firmware do you have?
how long are the files?
i remember i used to have problems with resume on audio book files that were longer than an hour.
