Sansa Fuze
Hey you guys i was wondering if there was a way to hook your sanza fuze up to your car stereo. My car does not have a tape deck and the reveiws for transmitters has been horrible so are there any other options?
Only if you have a USB or Aux In port.
Thanks,and how do i locate those options in my vehicle?
Look on (or around) your radio. If they’re there, you’ll see them.
And if not, you may need another radio, which supports line in and/or USB.
Or, you can try this solution, which I have just found on the Fuze+ forum/section/whatever you call it: Check it out!
There will be a jack on the front of your car radio–a USB port or a headphone-jack-like jack labeled AUX. Newer car stereos have them. Old ones don’t.
