Please keep all replies on topic regarding the current release of the Sansa Fuze Firmware.
We have confirmed a bug with Replay Gain in this firmware release. This bug only effects Fuze v2 devices. We are working on a new firmware which should be released very soon and have confirmed the issue is fixed. After the new firmware has passed a full QA cycle the new firmware will be released. If you have experienced this issue your options are:
1. Temperately turn off replay gain until the next firmware release is available
2. Use the following link to downgrade to the .26 firmware release. 02.02.26 firmware download and instructions
We would like to apologize for any inconvenience and we hope to have the new firmware available as soon as possible.
Follow the instructions below to verify the hardware revision of your Fuze before proceeding.
• Turn on your Fuze
• Select Settings from the main menu
• Select System Settings
• Select Info
• Verify the Version #
Revision 1 = 1.XX.XX (example: 1.02.26)
Revision 2 = 2.XX.XX (example: 2.02.26)
If your Sansa Fuze is a Revision 1 please proceed to the Revision 1 download and installation instructions.
If your Sansa Fuze is a Revision 2 please proceed to the Revision 2 download and installation instructions.
Let me start off by saying that majority of people will be able to update his/her firmware through the Sansa Firmware Updater. There is even a how-to video that explains the process. If for any reason the aforementioned steps do not work for you, then please feel free to continue by trying the more “computer savy” steps, described below.
SanDisk has just released the 01.02.28 and 02.02.28 firmware revisions for the Sansa Fuze. Download links and the release notes are available below.
Windows Users can Connect the device in any Mode and follow the instructions below.
Mac and Linux users can connect their Fuze in MSC or Auto Detect mode and follow the instructions below.
MSC mode instructions:
- Turn on the Fuze
- Navigate to “Settings” on the menu of the device itself
- Next select “System Settings”
- Next, navigate to “USB Mode” and select “MSC”
Sansa Fuze Firmware 01.02.28 download and installation instructions
For Sansa Firmware Updater - Click here to download
All Regions - Click here to download
All languages are now in one firmware version. After firmware update you will need to select your Language and Region preference.
• Ensure your battery is > 50% full.
• Extract the .zip file into a folder on your computer.
• Once extracted, drag the file to the root directory of your Sansa Fuze.
• Disconnect the Sansa Fuze and let it begin the firmware update.
• Once it finally finishes doing its update, it will turn itself off.
• Turn the Fuze on Select your language and region preference
• Once its back to the main menu, head to “Settings” > “System Settings” > “Info”, and verify the “Version” is now 01.02.28"x".
Sansa Fuze Firmware 02.02.28 download and installation instructions
• Once its back to the main menu, head to “Settings” > “System Settings” > “Info”, and verify the “Version” is now 02.02.28"x".
Sansa Fuze Firmware 01.02.28 and 02.02.28
Release Notes
This firmware has several bug fixes and enhancements, as listed below. Upon completion of firmware upgrade, the device will turn off. Power on device to complete the upgrade process. If device does not initiate or complete, press & hold the Power switch for 10 seconds to reset the device and then release and press again to restart.
Enhancements:
- slotRadio experience is enhanced
Bugs Fixed:
· Rating info is lost following database refresh on songs loaded in microSD
· Deleting video from microSD card doesn’t clear file from database
· FM playback stops when microSD card is ejected
· Device hangs if powered down during video playback
· Some language strings are incorrect
· Audiobook/Podcast count is not correct at Information screen
Known Issues:
· Some language strings are still in English
· Refresh database progress bar doesn’t scale with time
Message Edited by slotmonsta on 10-09-2009 04:21 PM
Message Edited by slotmonsta on 10-21-2009 10:57 AM
