Sansa Clip Firmware 01.01.35 & 02.01.35 Release
Klaipeda wrote:
Marvin_Martian , thanks. I see now, Nort America region in 02.01.35 doubles the sound level. U made me happy!:smileyvery-happy:
Glad I could help!
Pretty much what I was going to say – no new features, fixes to stuff that I’ve never seen an issue with, but happy/surprised that a new firmware came out for the classic Clip.   Thank you, Sansa!
@gwk1967 wrote:
I’m a bit disappointed in the lack of new features, but at least maybe this will silence the “Sandisk has abandoned us!” complaints.
Do not update your clip with this firmware if you wish to use it with your car hi fi system.
Sansa have sneakily enforced the dumb regulation from Brussells to reduce the volume.
When driving, it is almost impossible to hear music over the road noise.
I would never have updated my clip if Sansa had advised that this was going to happen.
If you’d taken the time to read a little bit here, you would know how to fix that low volume problem:wink:
Funny, the shaded (sticky) thread directly below this one you posted in has the answer to your problem. In fact, it is titled
Smiley
Smiley
Low volume after upgrading firmware
Don’t know how much plainer, simpler or easier to find the Admin could have made it. Maybe if he used flashing N E O N lights in the Subject title?
This thread should be sticky, it points to the last firmware.
The current sticky thread points to the previous release (0x.01.32)
Hi!
Can you add to Sansa Clip in the future - headphones (left/right) balance control? :wink:
Thanks!
@kingkong wrote:
Hi!
Thanks!
Kinda doubt it, since it’s discontinued and there probably won’t be any further firmware updates.
Maybe with the Clip+, it would be possible but it would be up to SanDisk whether A.) it _ can _ be done, and B.) they want to do it.
Ok. Thank you!
My software gone bad… It is still playing songs but some features have gone bad. Autoplay was one of it. My current version is 02.01.32p
I tried to update it but I couldn’t. I followed the instructions given over there but I doubt on my procedure. Somebody help me. I am using windows 7.
Thanks for the response… Let me show you my problem in a video. Just watch it here
http://www.youtube.com/watch?v=LZTRi2UWhmo
And regarding the autoplay http://picasaweb.google.com/pradeepkumar.phoenix/UntitledAlbum02#
When I tried to run the sansa updater it is saying that 'there is no internet connection… ’ thought my system is connected to net… I hope I have explained my problem clearly.
You probably have to adjust your Firewall settings. Your computer is trying to protect you from the “Evil” Updater. :smileyvery-happy:
Am having trouble (re)charging my new sansa clip. Have unsuccessfully tried to download whatever enabling updates may be necessary but can’t even complete version 01.01.30.
I cannot see/find  main menu.
Do you maybe have a v2 model and you’re attempting to put v2 firmware on it?
Download the firmware and follow the instructions (exactly) in the 1st post of this thread. You shouldn’t have any problems.
But then, updating the firmware is not going to solve a re-charging problem so maybe your troubles go deeper. Probably best to start a new thread about your particular issue.
I know this has been said here and in a lots of other forums, but I have to say it too.
It’s just unacceptable that Sansa Clip doesn’t allow folder browsing.
It’s not just about having your music correctly tagged. I have it correctly tagged. But sometimes one could just want to make a quick compilation of, say, music for running or music for doing some other activity.
Needles to mention that our parents and grandparents hardly know what ID3 tagging is.
I’m using playlists now but I (as many others according to what one can read on forums) would like an upgrade with that feature.
Good point…I’d bet most people had given up on any more updates. I’ll admit, I was skeptical too…I always hoped they wouldn’t “View” the Clip, but it’s nice to see they haven’t
url=[http://www.cartier4us.com/Cartier-Pen-5.html]cartier pens[/url]
To royalina -
If you would be so kind as to remove the spam from your ‘sig’ (before the Admin does it for you), I and everyone else here on the forum would be eternally grateful. Thank You!
Hi
    I tried updating my firmware without success.  Followed the instructions as presented.
I have a 1M Sansa Clip w/software V02.01.16a
Symptoms:
 1 -  When connected to computer the unit immediately goes to charging state even when 100 percent charged.  Following instructions for update, as presented has no effect.  This seems to be the only mode it goes too.
 2 -  Following my move of dragging the software update to the player icon’ computer shows software being transferred.  Following the steps to their completion, no update found on unit.
I also cannot load music to the player with original software because of the problem listed as symptom 1.
I use an IMAC w/ latest software.
