Is there anyway to remove the unlocker that comes with the SDSSDE81-2T00-G25
Hi @gazlong,
Thanks for your reply Keerti; I don’t think that I have opened a Support Case. Could you explain how I do this?
Many thanks
Gaz
I got the Sandisk Extreme back in January, it’s not the Pro version, it’s got 2 TB of storage. But man, it’s been giving me constant Error Code -36 messages and the speed is painfully slow.I even lost some files, but thank goodness. Ended up hittin’ up EaseUS and they helped me get my folders back. Lesson learned though - always have a backup on another brand device.SanDisk Extreme SSD Failure: Tips to Prevent from Further Damage
