SanDisk has released the ISO firmware images to allow SSD firmware update on operating systems that are NOT supported by the SanDisk SSD Toolkit. Each capacity drive has a separate Firmware ISO. You MUST use the correct firmware ISO for the capacity SSD you have installed.
WARNING: Applying the wrong firmware ISO to your SSD product will render the drive unusable! Please confirm the capacity of your SSD product before proceeding with the firmware download and update.
Note: The SanDisk Ultra+ SSD has two different model numbers. There is no functional difference between the two different model numbers. The Label on the SSD itself will always show SDSSDHP regardless of the internal model number.
Please verify the model number using one of the methods below. Do not use the SSD label to verify model number. Additionally you will need to know the capacity of your Ultra+ SSD and select the corresponding download below
Checking Model Number
Windows
Method 1 - Use SanDisk SSD Tool kit. The model number will be listed under Drive Info > Model
Method 2 - Under Device Manager > Disk Drives
MAC
1. Open Macintosh Hard drive > Applications > Utilities > System Information
2. In System Information on the left side select Serial ATA, The Model number will be listed on the top right window
Step 1 - Verify the capacity and model number (Using Device manager or SSD ToolKit) of your SanDisk Ultra+ SSD and download the corresponding firmware ISO
SDSSDH2-XXX
SanDisk Ultra+ SSD SDSSDH2-064GB
64GB X2306RL Firmware ISO
SanDisk Ultra+ SSD SDSSDH2-128GB
128GB X2306RL Firmware ISO
SanDisk Ultra+ SSD SDSSDH2-256GB
256GB X2306RL Firmware ISO
SDSSDHP-XXX
SanDisk Ultra+ SSD SDSSDHP-064GB
SanDisk Ultra+ SSD SDSSDHP-128GB
SanDisk Ultra+ SSD SDSSDHP-256GB
Step 2 - Burn the saved image file to a CD/DVD with another software application then boot from the CD and perform the firmware update.
Burn image with Windows 7 or 8: Right-click on the .iso file and select ‘Burn Image’
Burn image with Mac: Use Mac Disk Utility
Restart your computer.
For PC and Linux
Make sure the CD/DVD drive is the first device in the boot sequence defined in the BIOS, and restart your computer with the newly created CD/DVD boot disk inserted.
For Mac
With the firmware disk inserted Press and hold the “C” key while the computer restarts.
- After restart, your system will boot to the SanDisk Firmware Updater
- Select the drive you want to update from the list displayed.
- Press ENTER to start the update.
- When the update is completed, Press ENTER to shutdown computer.
- Remove the boot CD/DVD from the drive and restart computer.
