I formatted my usb drive but I think it is now with zero capacity and I cant use it to store anything on it…
i checked the properties, it appears that the usb has 0MB used storage and 0MB capacity… How can I fix this problem?
you cannot fix this the drive is defective and needs to be replaced.
here you can request a replacement:
These drives come pre-formatted from the factory. Rarely is there a reason to format again beofre using. But since you did format it, can you tell us how, or with what software? And to what format (FAT, FAT32, exFAT, NTFS)?
Have you tried formatting with different software and/or to a different format?
