SanDisk Professional G-DRIVE (18 TB) ticking sound
Hello, i have a problem with SanDisk Professional G-DRIVE (18 TB). First i had a ticking Sound all 2-3 Seconds. Then i replaced it under waranty. On the replaced G-Drive i had also a ticking sound all 5 seconds, and now the ticking sound is faster. But the drive isnt runing. So now i dont know if the second one is also bad? Or why it does this tick sound all 5 seconds?
Here you have 3 Videos from my own Cloud. (maybe it says no certification, still need to do that :slight_smile: ) : https://wohlgemuth.home64.de/s/2xQ5FtyAgWnzRoy
There you can see Task manager, Disk isnt doing anything. And hear the ticking sound.
Could it be that the second drive is also bad?
Hi @wdani
