Sandisk Extreme PRO and Extreme Plus concerns
So, I was researching what to buy for my H6B, and kinda dug into the Sandisk lineup and unearthed several oddities. Before I get into it, let me preface with the following assumption that I’m basing on the approved cards list: it appears that GoPros cannot yet properly utilize he UHS-II bus setup for microSD cards, and instead require the UHS-I setup. If this assumption is incorrect, then my assessment below changes slightly with regards to the Extreme Pro cards.
@arthurgretta wrote:
So, I was researching what to buy new projects in mumbai for my H6B, and kinda dug into the Sandisk lineup and unearthed several oddities. Before I get into it, let me preface with the following assumption that I’m basing on the approved cards list: it appears that GoPros property in mumbai cannot yet properly utilize he UHS-II bus setup for microSD cards, and instead require the UHS-I setup. If this assumption is incorrect, then my assessment below changes slightly with regards to the Extreme Pro cards. The Guardians
Any Updates???
GoPro site says UHS1 next to these cards when the label on both of mine says UHS3. Does that mean they are fake or old/new releases of the same spec card? why ? !
https://kodi.software/ & https://luckypatcher.cam/ & https://nox.tips/
Based on your statement, it seems you have been researching which microSD card to buy for your GoPro Hero6 Black (H6B) camera. During your research, you came across some peculiarities within the Sandisk lineup of microSD cards. However, before delving into the details, you want to clarify that, based on the approved cards list, it seems that GoPros are currently unable to fully utilize the UHS-II bus setup for microSD cards and instead require the UHS-I setup. If your assumption is incorrect, it would slightly alter your assessment concerning the Extreme Pro cards.
To provide a response in English, I have summarized your statement above. If you have any specific questions or need further information, feel free to ask!
cheap offshore vps Adult Video Hosting
