Sandisk Extreme 480GB SSD on Macbook Pro 15 inch mid 2012
If you still cannot get it to work, there may just be a firmware issue with the SSD and your relatively new MacBook Pro.
Firmware incompatibility issues are not that uncommon with SSDs, even with brands like the Crucial M4. If you still can’t get it to install, I would wait for the latest firmware to come out before pursuing warranty replacements, since you have 3 years and NewEgg won’t take it back.
So I ordered the same model from Amazon and it’s sort of giving me the same problems with starting up with the white screen and the flashing folder with the question mark through it but the only difference (good difference) is that when I go into disk utility while beginning the computer holding option, is that it always recognizes the hard drive and I just have to set it as the start up disk.  I am going to return the original one to Amazon today.  But why it occassionally doesn’t select the hard drive to start up is still not clear.  It could just be the firmware as you say.
It could also be the connector inside the MacBook that you’re plugging in - Use some canned air to blow out the connector on both ends, and make sure it’s snuggly fit to the SSD.
Which model MacBook are you using? ( Apple menu -> About this mac -> More Info -> System Report -> It’s the Model Identifier that I want )
I’ve got a 4 year old MacBook with the 120GB SSD in the HD bay and another 500GB HD in the DVD bay, and I never had any of these problems with it not being recognized EXCEPT when I tried to put it in the DVD bay. It would only work reliably in the HD bay.
Oh, and one more thing, that whole PRAM reset? It’s a thing of the past. What you want to do is reset the SMC controller. And it’s easy to do - Below is the method for a MacBook with a removable battery - If you’ve got a later model unibody MacBook Pro that has the battery built in,  here’s Apple’s article that describes how to do it for each model:
http://support.apple.com/kb/HT3964
SMC Reset on MacBook with removable battery:
Turn off
Unplug the MacBook from power
Remove the battery
Hold the power button for 5 actual seconds
put the battery back in
Plug into power
turn on
Actually, PRAM stores startup disk selection among other things. Not a thing of the past–still relevant on Intel-based Macs.
Hey thanks for the replies in advance.  I’ve been traveling back and forth for work so I haven’t had time to check this out.  My macbook is a mid 2012 15 inch nonretina display.  The 2.6 GHZ with 8 gb of Ram and the 750gb HD.  Here is the info you requested.
Model Identifier:MacBookPro9,1
Hope it helps and can jog your memory so that I can finally resolve this issue.
And i forgot to mention it is connected to the HD Cable.  I still have my dvd player installed.
I am also having the same issue. I removed the drive and tried it on another macbook pro using the internal SATA and it booted. I am still troubleshooting . =\
Fixed the issue on a temporary solution .   But first let me give the backstory to it.
I was using my mac(mac 1) when it froze. I procceded to reboot and do a pram and smc reset. after this I received a light gray screen with a dark grey folder with a question mark. ( this usually happenes when the drive is not avaliable. ) I then pulled the drive (SANDISK SSD PLUS )out (mac 1) and install it on my other mac2 (mac2), and saw that it booted correctly . I then used the drive from mac2 and installed it on mac1 and it booted correctly. At first i thought maybe that the SATA cable inside the mac1 was damage ( as I have already replaced it once ) .      Well in the end the Temp solution was to pull SATA CABLE from MAC2 and Install it on mac1 . then i installed the SSD back to the MAC1 and it works fine. tomorrow I will contact apple and sandisk to what may be the issue .
I also have an issue with an SSD disc that works, but doesn’t work.
In my case when I shut down the MacBook and turn it on with the power button, I get the document with question mark and the MacBook won’t start.
When I turn on the MacBook with the power button and do a PRAM reset, it boots perfectly fine and the SSD works like a charm.
Restart is no problem, it boots up normally…but…when I shut down and power up again the document with question mark is back. Then, When i reset PRAM again, it boots, and so on…
So:
  • SSD is working fine
  • did all checks with disc utility and already formatted with GUID table and reinstalled with no different result
  • SATA cable seems fine, after PRAM reset everything is working fine
  • tried PRAM reset, but this only works that specific boot up. Next time I shut down I need to reset PRAM again to be able to boot into OSX.
  • of course I also checked startup disk
  • even tried repartitioning with same partition size to force a new EFI or master boot record
nothing helps permanently…
I really feel I am missing something obvious, but read so many forum posts and tried every suggestion without prrmanent result.
Who will give me the freeing advice on how to make my MacBook understand it has to boot from the SSD?!
thanks for any help!
How do I installSandisk
